Toyota 4Runner Ditch Lights & Brackets
ExtremeLED
Toyota 4Runner (2010-2019) Stackerz 2" LED Light with Ditch Brackets
If you've been looking for a unique look and a specific fit, our Extreme Stackerz may be exactly what the Doctor prescribed. The modular design lets your imagination run wild to come up with the exact look you've been searching for.
Run a single light when needed in a compact area or motorcycle, or stack them together to the perfect width or height for your application for a truly custom look.
Made of rugged aluminum and features a high output single CREE LED, which means you don't have to sacrifice light output in such a small package.
Our LED lights also include a lifetime warranty and 30 day risk free returns. So give them a try...you've got nothing to lose.
  • 2" Wide x 2" tall x 3" deep
  • spot beam
  • 10w CREE LED
  • 1,000 lumens
  • each light comes with mounting hardware and stacking hardware to use if you purchase more than one
  • Note: these are not plug and play with our harnesses, but you can simply either cut the plug off of our DT harness and splice it to these lights or purchase a DT Male pigtail for Stackerz and splice it to these lights which will then make them plug and play with our DT Harness (these items come in this bundle).
Check this package out here
charlesz
