Toyota 5th Gen 30K Maintenance/Service Buyers Guide
ReluctantNomad
Toyota 5th Gen 30K Maintenance/Service Buyers guide:
My 2014 4Runner Limited is coming up on 30K miles and is now out of Toyota Care. I am the Reluctant Nomad so working on the vehicle is difficult (no garage, apartment complex, and avid desire to not have clutter). Dealership wanted $380 for full 30K service, ~$280 for piece meal and self air filters replace. I decided against dealer after they quoted $160 for lubing zerk fittings.
Maintenance items recommended @ 30K:
- Oil Change (big monster)
- Lube zerk fittings (big?/new monster)
- Retorque Drive Shaft bolts (small to medium monster)
- Tire Rotation (medium monster)
- Air (cabin and engine) filter replacement (easy monster)
- Inspect fluids, brakes, etc.
Parts:
Oil Change ($59-66 + $105 in special tools):
- 6.6 quarts Synthetic 0W-20 oil - $ 51 [Amazon Link - Qty: 2]
- Oil Filter Kit (04152-YZZA5) - $8 [Amazon Link]
- Oil Drain Gasket (90430-12031) - $7 [Amazon Link]
OR
- Fumoto Drain Valve (I chose F-103N, has a nipple) - $25 [Amazon Link]
- Fumoto Plastic Clip (for additional security/piece of mind) - $9 [Amazon Link]
- Suggested: Anti-Sieze Lube (for skid plate bolts only) - $4 [Amazon Link]
Oil Change Special Tools:
- Oil Filter Wrench (TOY640) - $18 [Amazon Link]
- Funnel - $5 [Amazon Link]
- Extra Large Drain Pan - $11 / $24 [Amazon Link: Option 1 / Option 2]
- Car ramps - $60 [Amazon Link]
- Wheel chocks (pair) - $11 [Amazon Link]
Lube Zerk Fittings ($27 + $84 in special tools):
- Grease for Spider fitting (Lithium base chassis grease NLGI No. 2) - $18 [Amazon Link]
- Grease for Slide yoke fitting (Molybdenum disulfide lithium base chassis grease NLGI No. 2) - $9 [Amazon Link]
Lube Special Tools:
- Grease gun with flexible hose - $42 [Amazon Link - Qty: 2?]
Retorque drive shaft bolts:
- No parts required, just labor and tools
Torque Special tools (Labor + $85 in special tools):
- Torque Wrench calculator (if using crowfoot/box-end with torque wrench) - [Web Link]
- Torque wrench - I chose 3/8inch (should support 10-oil drain, 65-propellor shaft, in lb-ft) - $35 [Amazon Link]
- Crowfoot Wrench Set (need 14mm and 17mm) - $52 [Amazon Link]
Air Filters ($47):
- Cabin Air Filter (87139-YZZ10) - $25 [Amazon Link]
- Engine Air Filter (17801-38051) - $22 [Amazon Link]
Tire Rotation ($25 or labor + $35 torque wrench):
- Costco Tire Rotation - $25
- Optional (if you want to DIY): Torque wrench - 1/2 inch (should support 80-90 lb-ft) - $35 [Amazon Link]
Total cost of replacable items: ~$133 + labor
My shopping cart shipped (includes most the special tools): ~492 ($452 pre-tax/ship)
Technically more expensive then dealership, but meh. Did not feel encouraged by their service offerings. Also, possible opportunity to make some friends.
How to do all the maintenance:
Oil Change How-to - [Link]
Torque drive shaft, Lube zerk fittings, Air Filters, pretty much all the rest - [Link]
Credits:
Pretty much the whole T4R forum. Some key threads and members below:
- renau001 DIY maintenance quick reference - [Link]
- AntMans Oil Change How-to - [Link]
- Mijfwb23 Prop Shaft greasing - [Link]
- WhiskeyCop 5Gen Maintenance thread - [Link]
I would add that a brake fluid flush is something I recommend to all customers every 3yr/30k (also what I do on my own vehicle) as well as replacing all the Differential Fluids (at least the first time, if you go fancy synthetic then you may want to adjust the interval some.)
Why flush the brake fluid at 30 K? That would be yearly for me.
excellent info for a noob to know. I'm a low mileage driver but need to find this again when the time comes.
thanks
lindwlson982
