Toyota Advances D4S With Self-Cleaning Feature
NoDak
Senior Member
interesting article if this is going into the 6th gen 4runner
TACOMA, WA – Toyota advances its D-4S port- and direct-injection system with the technology’s installation in the new Tacoma midsize pickup.
The automaker believes it has solved the conundrum of carbon build-up on injectors with a new self-cleaning feature for D-4S, a technology that debuted 10 years ago on the ’05 Lexus GS 350 and ’06 Lexus IS 350 and today is used in the current-gen Lexus IS, GS and RC and Scion FR-S sports car.
“What we’re doing is we have a slit on the side of our injector and we’re blowing that carbon off,” Mike Sweers, the ’16 Tacoma’s chief engineer, tells WardsAuto here during the truck’s media preview. “If we tried to use just high pressure, using just the nozzle itself, you would clean the bottom of that nozzle.
“But since the carbon grows from the outside and comes around, you would still plug up that injector,” he adds. “So by cleaning on the outside of that, we get a clean injector all the time.”
Drivers may hear the self-cleaning taking place during a hot idle, and the process could last from 10 seconds to as long as 10 minutes, depending on driving patterns and the amount of build-up on the injectors.
“When you go into a hot-idle situation, the system is going to look at the time that it ran, the number of cycles the injectors went through, the temperature of the injectors and then it goes into a self-cleaning mode,” Sweers says. “Because we have the port injection, I can continue idling the engine without having any side effects.”
He compares the technology to a self-cleaning oven, as no additives are necessary.
“You stop at a light (and) it may clean for 10 seconds, you’re going to take off and stop at another light and it’s going to clean for (another) 10 seconds,” he says, noting the engine will deliver torque when a driver wants it and shut off the cleaning mode.
The 10-minute cleaning cycle occurs during longer idling, such as in a drive-thru line.
The next-generation D-4S is paired with the next generation of Toyota’s 2GR engine family, the 3.5L 2GR-FKS. The previous iteration of 2GR, 2GR-FSE, is a 4-time Ward’s 10 Best Engines winner.
Both 2GR-FKS and 2GR-FSE are all-aluminum Atkinson-cycle engines. But differentiating the new 2GR from the existing 2GR are reduced-friction oil sumps, a new variable-valve timing system that shifts between Otto and Atkinson cycles and an exhaust manifold integrated into the cylinder head, a design that has a variety of benefits, including weight reduction and the ability to use engine coolant to cool exhaust gas.
“One of my favorite parts of the engine is we eliminated the exhaust manifold on the engine and put that into the head of the cylinder head itself,” Sweers says. “So by doing that we can cool the exhaust gas. And by cooling the exhaust gas I don’t have to pump any raw fuel into the catalyst to keep the catalyst cool, because I’m not heating the catalyst up as much.”
A side benefit of the design: the catalytic converter is closer to the head, making theft less likely.
“You can’t get up there and take them,” Sweers says. “It’s amazing what you can do with a Sawzall,” he says of a reciprocating saw often used by thieves to cut off easily accessible catalytic converters.
Catalytic converter theft is on the rise, as the emissions-control device contains valuable precious metals and more Americans are driving light trucks that sit high off the ground with easy access to their undercarriage.
The Tacoma’s 3.5L V-6 makes 278 hp and 265 lb.-ft. (359 Nm) of torque. The outgoing ’15 Tacoma’s 4.0L V-6 produces 236 hp and nearly identical torque. The 3.5L’s horsepower and torque peaks at 6,000 and 4,600 rpm, respectively, compared with 5,200 and 4,000 for the 4.0L.
The new V-6, combined with new 6-speed automatic and 6-speed manual transmissions, improves the Tacoma’s fuel economy by up to 2 mpg (0.8 km/L) city and 3 mpg (1.3 km/L) highway. The biggest increase is seen in highway fuel economy in the automatic-equipped 2-wheel-drive Tacoma, which is rated at 24 mpg (9.8 L/100 km) vs. 21 mpg (11.2 L/100 km) in the similar outgoing model.
However, the 24-mpg figure still falls short of the ’15 2WD 3.6L 6-cyl. Chevy Colorado, achieving 26 mpg (9.0 L/100 km) highway.
Toyota carries over from the ’15 model its 159-hp 2.7L 4-cyl. for the ’16 Tacoma, which can be mated to the new 6AT or a carryover 5-speed manual.
Toyota says the new 6-speed automatic is lighter and with fewer components than the ’15 Tacoma’s 5AT, and the 6-speed manual boasts more robust carbon synchronizers and improved shift feel vs. the ’15 Tacoma’s 6MT.
The ’16 Toyota Tacoma goes on sale Sept. 10 in the U.S.
original article : Toyota Advances D4S With Self-Cleaning Feature on Tacoma | Vehicles & Technology content from WardsAuto
hopefully however they have designed these heads the exhaust manifolds wont crack and you would have to replace the head if it does crack.
Interesting. I was always under the assumption that the cats needed to be hot for them to work. I'm also curious how the heads will hold up now that the exhaust manifold is part of them. Thanks for sharing!
Okay, so it's a 2GR based engine block; been wondering what the designation was going to be for a while...
Eh, I need to see the exhaust manifolds in person; that sounds like it will be problematic later down the road...
GM has been using an in-head exhaust manifold design in their 3.6 V6, for awhile now. So far, I haven't heard of any issues.
Here's their design:
I'd love someone to take a pic of the engine when one rolls into a shop bay. Anyone know what the sump size is on these engines?
I'd be real curious to what the temps are at the manifold.
I don't know how the idea of not having the cat easily cut off by some drug induced hack will appeal to a new buyer.
