Toyotec lift
toyota4
Just Spock to toytec again the my lift and they say they are out of the shocks for the complete lift that cost $909 they only gonna get it at the end of the week so now they offering the ultimate kit with 7% off (not like the normal 5%- not a big different but could be vary good news for someone who's ordering them anyways...
So my Question is is the ultimate shocks a really big improvement over the $909 kit? I don't think I really need the option to adjust them (not planing on custom bumper or anything like that- but it never hurt to have the option...)
What do u guys think?
If you don't think you're going to adjust them then you probably don't need to spend the extra money.
Looks like 3" is the max on either option?
You could also get the $620 bilstein front kit and add the superflex coils ($180) and bilstein rears ($200) and save $200 over the ultimate. The only difference is that you'd use your OEM top hats.
Diff drop is another $30 if you want that but I don't think most people use it.
agreed.. the only benefit you'll see with the adjustable coil overs is you have the option to soften or stiffen up the ride to your liking. speaking of the front spring pre load only of course.
Isn't the shock itself thicker in the ultimate?
Is anything wrong with useing useing the OEM top hats?
The toytec may have a larger diameter spring I'm uncertain. I believe a sway bar relocation kit is required with the setup so I can assume that they are indeed larger.
nothing wrong using the OEM top hats I have them on my front Old Man Emu struts and believe me they've seen they're abuse.
The shock itself is the exact same in all three kits, it's just a Bilstein 5100. I haven't seen anyone else complain about the OEM top hats, they're just not as nice looking as the TT units.
It seems like all 3 would have to have the same size coils in order to be able to use the TT or OEM top hat and work with the 5100 or TT adjusters.
The $1000 kit I described also includes sway bar relocates and the red 'ultimate' front coils either way.
thanks for clarifying I was shooting from the hip on that answer.
In short... If I'm not planing to add wight than the $909 is just as good as the other options? Or there is any benefit other then adding wight?
Just Spock to toyotec again the my lift and they say they are out of the shocks for the complete lift that cost $909 they only gonna get it at the end of the week so now they offering the ultimate kit with 7% off (not like the normal 5%- not a big different but could be vary good news for someone who's ordering them anyways...
who is "toyotec"
spellcheck/proofread
They tried doing the same thing with me in giving me a discount on more expensive front end components, but I just decided to wait for the backorder and they said I should have them by the end of the week. Anyways as for reading this thread are you saying that with this kit 3" Lift W/ Bilstein 5100 Height Adj Coilovers FJ/4Runner - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
I need a sway bar relocation kit?
I don't have a clue with this stuff?
That's the kit I have, no sway bar relocation needed.
Called again and they said they still haven't heard from their supplier so they cant really do anything. While understandable just sucks as I want to get my rig lifted already.......
why not go with the radflo CO's see if they'll supplement the kit with the radflo's?
They offered their fully adjustable at a discounted price, but I have no reason for fully adjustable on the front end, as I plan on leaving it at the set height with the new bumper and everything on the front end it should level out. And damn those Radflos aren't cheap?!?!
I just want a lift already. . .
well to be honest if you have plans for a bumper and winch or possibly other weight on the front end the adjust-ability is a benefit to your favor. As you add weight you have the ability with adjustable coil overs to maintain the lift height you desire even as you add more weight.
and the radflo's are a solid investment the company takes great care in all of they're customers they will rebuild them for you at any time basically allowing you to never have to purchase another shock body again. Being rebuild-able other 4x4 shops are also capable of rebuilding and re-valving the shock bodies.
I just ordered a set of there 2.5 extended travel this morning lol I'm all for some radflo's.. If there discounting them accordingly I'd go for it..
Just a side note... I was also able to level the side-to-side lean by adjusting the front coil-overs. It didn't take much at all (maybe about 3/16" difference between the coil-overs), but I got it sitting almost perfectly level. I don't feel that that slight of a difference has had any impact on ride/handling either.
Aren't the coilovers in the Toytec kit in question adjustable because of the Bilsteins?
You're right! I think of 'adjustable coil-overs' as actual adjustable coil-overs with the threaded collars. I just looked at the link and the kit referenced can be set up to achieve different amounts of lift by way of various spring perch positions on the shock body.
I have the Ultimate Kit with the threaded adjustment collars... FJ Cruiser/4Runner Ultimate 3" lift package - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
With all that adjustment, I'll never be bored!
I've got the toytec bilstien/superflex kit set mentioned previously and I've had no problems from it yet, I think it ran me just over $800, seems like they gave me some kind of added military discount over the phone when I called. Def call to order whatever you decide to go with instead of just ordering online. They are good about adding discounts over the phone.
Talyn
