Toytec Body lift
I installed my body lift by myself and yes, it was a PITA. Took about 5 hours solo but you can shave a bit by not having to install a radiator drop and having a buddy help you. I will say that the steering column spacer is pretty much impossible to install without unbolting the entire steering support structure. I ended up just using a bunch of washers as spacers and everything went together just peachy.
Ive installed a few of them, I wouldnt say they are "hard" to install, time consuming yes...
Just take your time, read the instructions, follow the instructions and take your time, you will be ok :pimp:
EDIT:
a good idea is to start spraying things with PB Blaster, this will help losen things up.
Me and a buddy did mine in about 3 and a half hours with rad drop and steering spacer it really isnt that bad. We just made sure we knew everything from write ups before we did it
lindwlson982
