Toytec lift advice
df662
Ok guys, need some advice here. I have had bilstein 5100 front/back (1.75” front, 1” spacer in back) installed for the past year or so on bfg ko2 275/70/17 .I am thinking about pulling the trigger on the Toytec lift kit below and SPC uca. I dont do any serious off roading. What are your thoughts on this setup with the bilstein 5100? Is there anything else that I would need? Are toytec springs side specific to correct driver side lean? If not, what do I need to correct that?
Also, anyone in the Portland , OR area that can recommend a shop for install?
3" FJ Lift w/ front & rear coils
25480 - SPC Adjustable Upper Control Arms for FJ & 03-Current 4Runner
If you go to higher lift the shocks might be too short as they were designed for the shorter lift the shocks may work but may result in a rough ride if they are extended further out due to additional lift . Also the coil springs aren’t side specific but are front to back specific and to fix the lean you would need a coilover that has an adjustability. And I used the search function and found you may need a diff drop at 3” to maintain good angles.
Disclaimer: I have not used either of those lifts but I have lifted multiple vehicles in the past.
Mike Sargent
