Toytec lift question
Slick8810
I have a 06 Sport 4wd and was wondering if i go with the 3" spacer or coil up front and nothing in the back will it make it sit too high in the front? i just want it level but it seems to me putting 3 in the front and 2 in the back will make the back of it taller.
3" in the front will be WAY too big to level it out. If you're just looking to get rid of your rake i think you need a 1 1/4" spacer (I could be wrong). But If you only have 3" up front you'll be seeing sky while driving.
I have a 1" Toytec spacer lift up front and it does a lot to level out the 4R. It doesn't eliminate the rake all together, but with a full tank of gas and camping gear in the back it won't sag in the back. You want (at least in my opinion) a little bit of rake, but a 1" lift up front will be a huge improvement over stock.
If it's a top out spacer, you'll get twice the lift as the spacer thickness. So, a 1 inch thick spacer will lift 2 inches (which is about what is needed). If it's a preload spacer, you get the spacers thickness for lift. I've done some looking, and I've not yet found that "perfect" spacer. Most seem to be either a little too small or a little too large, no in between.
as long as you dont have the rear airbag adjustable suspension, I think it would work, but im not 100% sure, maybe someone can verify for me
