toytec sway bar relocater
There's pics on the google web...
Here's one from a Taco:
DSCF0402.jpg~original
But, install is pretty straight forward.
Remove the 2 bolts holding on the U shaped bracket from the sway bar bushings, you can do one side at a time, just don't tighten anything down until you have it all together.
Place the relocator on the frame, remember you want to move the swaybar away from the spring, so the holes that have the recess are for the bolts going into the frame.
Goes on like this
Front of vehicle----->
Front_Swaybar_Re_49f206334d3b9.jpg~original
You don't have to lift the vehicle, unless you need some room, which I don't think you do.
ive got a toytec ultimate and the sway bar is rubbing the lower part of the shock, sqeeks alot
thanks for the reply and the pictures!
