Toytec vs. Tundra Coilsprings
BFEATHER2008
Was wondering what is the best option? I work at a toyota dealer and can get both the springs and struts/ shocks for tundra under $300 bucks. Any advice is appriecated. Thanks
My first lift was a set of Tundra TRD coils.
Make sure that you get the color code from him first (paint dots on the coils), Tundra TRD Coils. Left, 48131-AF100 (Yellow/Yellow). Right, 48131-AF090 (Blue/Yellow)
The TRD coils fit:
4wd, access cab, w/off road pkg. 2000 - 2002
2wd Access cab 2003 - 2004
4wd Access cab Left 2003 - 2004
Depending on the year of the 4runner (some years sat higher) you will get
1.5"-2"+.
They are about a 575#-595# spring rate.
The ToyTec COs are usually a 600# SR. This is what I'm running right now. They are real close to the same ride.
Ok thanks. but the color code I would be buying them brand new since i work for the dealer i can get them cheap new. so i wont be buying used how can i tell then? or do u have part numbers from what you had or do you still have yours? Oh and my 4Runner is a 98. Thanks
