TPMS for aftermarket wheels
81reaper
I am replacing the stock 17" wheels on my 04 SR5 with a set of 18x9 wheels. I will be installing 285/65x18 tires.
Is it common practice to reuse the factory installed Tire Pressure Monitoring System devices for use in the new wheels?
If not; what are my options.
Yeah, they'll just move your sensors over to the new wheels.
Options? I guess you can just have them put in regular valve stems and dump the system, then you'll have to either live with the light or figure out something to do about it.
Hope that helps.
That does help superman. Thanks.
I was hoping that the TPMS would just swap right over, but wanted to make sure.
I didn't want any surprises at the tire store. The sticker shock is already going to be enough of a surprise.
No TPMS on my 04 SR5
As the title states, I have an O4 SR5 and although the sensors are in the original wheels, I don't believe I have a TPMS. I put on a set of snow tires/rims last year and ran the whole winter with no light. Many trips were over 100 miles and I did not park in a garage next to the summer rims. They were about 40 feet away in the basement. If you haven't already switched, air down a tire or two to something like 25 psi and see if your tire light comes on.
I'm not sure if mine is just broken but a quick internet search turned up that vehicles were not required to include TPMS until 05. Again I don't know when Toyota installed TPMS on our 4Runners but I am kind of glad I don't have to see a light on all winter (or buy sensors just to turn off a light).
Thanks for the reply 04 4runner.
I am certain that mine is working as designed. I have been planning a wheel and tire upgrade for about 6 months now, and in that time I have been postponing patching a hole in one of my worn out tires.
Every 2 or 3 days, the light comes on the dash telling me that I have a low tire. The truck won't let me forget about it for sure.
I almost wish I didn't have this as well, but then again, I would probably have had a flat by now.
