TRAC OFF, VSC TRAC, ABS lights on
mini_fly
I have a 2001 4Runner with around 82,000km on it.
Today I stopped at a friends place to drop something off and left the truck running.
When I got back in, I could not shift from Park and the TRAC OFF, VSC TRAC, ABS lights were on.
I shut the truck off and restarted with no luck.
I used the Shift Lock override button to get going again and drove to my dealership who told me they would have to hook it up to get a diagnostic code.
Before I shell out any money to find out it is something simple, can anyone give me an idea on what it may be?
Thanks,
Henry
The only way you can find out which code was set in the ECU is to read it with a OBDII set.
The lights can be reset with the same set. The code will tell you what caused the problem.
Cliff s
I just brought home the Snap-On code scanner from work but I can't get it to recognize the truck in generic OBDII mode.
Anyone use one of these have any insight how to get it to work? The scanner starts up when I plug it into the connector but it does not seem to communicate with the truck otherwise.
Thanks,
Henry
Different makes of vehicles use different pins on the OBDII plug.
There should be a switch on your code reader to set it too the
different makes. Check the instruction book.
Cliff s
Do your brake lights work? I had this same problem on my 2003. It was a blow brake fuse cause by a short in the rear spoiler stop light.
