Trail Edition Wheels
Chilow
Hello,
Just picked up a 2014 SR5. Does the Trail Edition wheels fit the SR5 without modification? I tried searching, but didn't find any information on it.
The goal is to do a moderate lift (probably Bilstein 5100s and KO2 tires)
[MENTION=66316]1engineer[/MENTION] I'm beginning to think that in addition to 15 posts, we need something to insure new members have at least looked at the stickies section.
Must read and accept and answer a shot quiz after. Just like getting a fire permit.
Hello,
Are you planning on putting 285s? Don't forget to ask if they'll rub especially with spacers.
Could be worse, at least theres not the "which oil should I use" question being asked multiple times a day like some forums...ugh!
1. I did read the sticky.
2. Nowhere in the sticky does it specifically say anything about trail wheels on the SR5, instead focuses on tire size.
3. Thanks for the sarcastic comments
I'll be helpful here. Yes, they will fit. They are a bit wider but no issues are expected unless you go up in tire size or you run spacers. If you plan on doing either of these then have a look at the threads that address rubbing and what to do to remedy it. Cheers!
Don't mind the grumpy old folks in here. They are just irate that there are no new questions that can be asked regarding the 5th gen since they know them inside/out and top/bottom. :eyebrows:
In their defense they probably see the question on a daily basis. If you searched and found nothing specifically answering your question then never hesitate to ask. People will whine but in the end someone will answer your question.
Sticky-recommended search (aka Google) for "TE wheels on SR5" or "TRAIL wheels on SR5" easily yields multiple answers in .46 seconds.
You're welcome.
Some members should get safety pin banners under their handle so that newbs can safely practice forum redundancy without grown ups and sarcasm ruining their day.
You're welcome.
https://lmgtfy.com/?q=5th+gen+4runner+trail+wheels+on+sr5
Please share with me your results that you received in .46 seconds that answers my initial questions. As you will see in the link I provided, searching for 5th gen 4runner trail wheels on sr5 yields no pertinent information on Google.
I'm sorry, but post #13 tells you exactly which Search technique I used, and exactly which Search Criteria I used, and I was criticized for that. I didn't make that post without doing it myself first (and of course actually READING through the results - gasp!) Either your Google-fu needs work, or you wish to be spoon-fed.
The exchange of wheels between ALL 5th Gen 4Rs (SR/LE/TE) has been discussed multiple/multiple times since 2010 (you joined in 2011) !!!
I always helped my kids with their homework, but I never did it for them. They didn't like it, but they can think for themselves now. /done/
Not being sarcastic. We ASSUMED that you would know that all 4Runners have the same hubs, frame, similar suspension components, etc. Now, the link I provided you shows a chart and talks about the only difference between the different model's wheels. It's towards the bottom and talks about wheel width and backspace. Here:
I like OPs idea here...I'm picking up my "new to me" 2014 SR5 4x4 tonight, and think that the TE wheels are cool upgrade, with that classic look. ...and save about $300 over the TRD Pro. The TEs look cool coated as well.
anyone know of any weight/performance pick-up from going stock to TE wheels.
DJNutshell
