Trailer wiring converter.
Are you sure it is the truck? If you have tested the harness on the truck with one of those handy $4 testers ....read on.
The trailer gets it's power and signals from the tails. Toyota's turn signals are on a shared wire so the trailer wire needs a converter to know which is left turn and which is right.
On my 99 LTD, the converter box you are looking for is mounted behind the cargo bay trim on the left side (when looking from the back).
They are not fused so they tend to blow.
A replacement from Toyota is an obsene amount of money > $200.
I would not remove the existing but rather install a new one.
I installed an aftermarket converter that plugs right into the tail light plugs. Only had to route one wire over to the other side. I tucked it behind the inside cargo wall on the right side, under the storage box. $30.00
Check Napa, Autozone, etc for one that is specific for Toyota 4 Runner.
One looks like this:
Came from
thiswebsite
Steps to access converter:
Remove the sill cover screws. Gently pry up. There are clips. Pry close to the clip so they don,t break.
Remove the cargo cover latches.
You want to pry the side panel out just enough to reach in and access the connector. Be gentle.
