Trailer / Rear Gate / Windows Electrical problem
N8800SS
So my 03 Sport recently decided to have a major electrical melt down.
These items do not work:
1. Power windows (all)
2. Rear Gate (no power at all)
3. Parking Lights (all)
4. Dash lights (illumination)
5. Constant 12 v power to parking light on trailer pig tail
What I have tried for each:
1. Fuses - (all, multiple times, visual and ohm/power check); window lock out switch , swapped relays
2. Fuses (all), getting power to ECU, swapped relays, unplugged battery and ECU for 10 min.
3. checked bulbs and fuses
4. checked fuses
5. Traced power (black/green wire) from pig tail all the way to source, constant 12 v throughout...
I know the rear gate ecu and lock mechanism can go on these vehicles. However, with the other issue described above I'm not convinced this is the problem. I found out about the trailer parking light issue when I hooked my trailer up and melted the wire on the trailer.
I'm at a loss on where to go from here... next stop: stealership....
I suppose I didn't ask a direct question... Anyone have any thoughts? Similar experience? Can the dealer diagnose the problem without throwing parts at it?
4. checked fuses
Check for shorts in the body ECU. That's just a suggestion coming from here because the drl's/parkling lights are all in the body ecu, so i think all these other parts are, too. If not there, check for a major short coming from the battery to the main ECU.
tuṣṭāva
