Martinjmpr
(Also posted on Expedition Portal: Vehicle-Dependent Overland Expedition Community)
Something's come up and without getting into the details, I may have to help someone move on fairly short notice, from Billings, MT to Denver. Not sure how much stuff he has but I know when he moved to Billings last year he had to make a couple of trips. He's got a full size Dodge Ram 4x4 pickup which I assume can pull a pretty big trailer.
Anyway, if we have to move him, we'll be doing it in one shot, most likely. My thought is that I could help him out by pulling a trailer as well.
Here's the thing, though: I've only pulled a trailer (for any distance) once before, when I moved from Denver to Laramie, I rented a 5 x 8' Uhaul single-axle trailer and pulled it behind my 1999 Ford Ranger using a bumper hitch (actually, a ball mounted on the factory step bumper which was supposedly rated to 3000lbs.) I had no problems but the move was "only" 125 miles.
So here are my questions:
1. Looking at the manual, it says my 1999 4runner with the 5vz 3.4l V6 motor can pull 5,000lbs. That seems way too high to me! I do not have the "heavy duty towing package" to my knowledge (how would I check?)
2. My truck does have a Class III receiver and an electrical connector, so all I'd need to buy is a socket with a ball to go on the receiver. Any recommendations?
3. The manual says that if the trailer weight is over 2,000 lbs, I need a "sway control." What is that? Is it something electrical or mechanical? How difficult/expensive is it to put one on? I'm particularly concerned about sway because the 560 mile trip from Billings to Denver is over the open plains and there are often heavy crosswinds.
4. Assuming I get a smaller (5 x 8') trailer (single-axle), with a trailer weight of <1000 lbs and a loaded weight of <3000lbs, do I need a trailer brake? Right now I don't have one. Honestly, I'd like to keep the trailer as light as possible by carrying bulky-but-not-heavy items.
5. Currently I do not have an auxiliary or aftermarket transmission cooler. Should I get one before I make this trip? If this was a cross-town trip or even a 125 mile trip to Laramie, I wouldn't worry, but 560 miles is a long drive!
6. Any other tips/tricks from the veteran towers out there?
Thanks in advance!
Thanks in advance!
