SAC-CA-Runner
Today I put in a B&M 70268 Cooler along with one of those Permacool spin on filter that another guy had on his. However I put the gauge up as well. Sorry no pics, right now but will get some when it's light out.
Anyway...how much fluid are you guys adding when you add an external cooler? And what is the proper way to check the fluid when cool/hot?
I ran the truck for a while as I also put a new radiator (my own dumb mistake, don't ask...but probably could've used one anyway) in. But I let the truck run a while and then put it in R, D, L, 1, 2, etc. and pulled it back in. Shut it off then checked. I put a half a bottle in and it's still read low on the cool side. So I used the rest of the bottle and went to R, D, L, 1, 2, etc and checked again with engine off and it was a little bit more than cool.
So how and when do I check when its hot? Drive the actual truck and look at my temp gauge (got the ultimate spin on filter kit) and then check? Running or not running?
Also, got my Tundra brakes on, spacers, sway bar bushing front and rear...pics to come as soon as I have time.
