:iagree:If the A340 uses the same layout as the V-6/A750, the bottom port is the outlet/return to the trans from the radiator cooler. If you go to toyotapartszone.com, you can pull a labeled parts diagram that should tell you which rad port is the inlet and outlet.
-Brent
