By adding a tranny cooler or e-rated tires or air bags in the rear your towing capacity will not go up. Its set by the manufacturer for multiple reasons, axle capacities, weight and size of vehicle come to mind. The tranny cooler would help the longevity of the transmission. That said, there is no dip stick to check the fluid level. Theres a rather long drawn out procedure. You have to pull the check plug (by the drain plug) when the temp of the fluid is between certain degrees, and add fluid until it comes out, or wait for it to stop coming out if over filled. The fill plug is on the side higher up.
Doesnt the Tacoma have the exact same drivetrain? Im talking about the 2011. I realize the vehicle weight may be a little different, Just trying to increase the tow capabilities so im sure i am not overloading when I tow 5k pounds (the limit). Sorry if I sound stubborn.
The total towing weight capacity is always tongue weight multiplied by 10.
I read that by doing a few mods I could increase my towing capacity to that of the Tacoma..
I read that by doing a few mods I could increase my towing capacity to that of the Tacoma. One of the mods was a tranny cooler, how do you do that when the tranny is sealed? There is no fluid check stick, no way to fill it back up.
I already put airbags on (airlift 1000) I already have an anti sway bar, load leveling hitch, trailer brakes. Its not soft azz anymore! I have had 800 pounds on the hitch for a short distance with my work trailer, no sway bar, no load leveling hitch. It drove pretty good. :ak472:
im not talking about towing more than 5k. I just want to make it easier on the rigs drivetrain
you are correct, I am trying to get the 4runner capable of towing more. I feel that if i could accomplish that, it would be less stress on the stock :toilet:drivetrain.
im not talking about towing more than 5k. I just want to make it easier on the rigs drivetrain.:boxer:
you are correct, I am trying to get the 4runner capable of towing more..
NO. There is nothing you can do to increase the 4R's towing capacity, period.
You can make the ride/handling better with bags, etc. Use Search.
You can, perhaps, improve tranny longevity with a cooler. Much discussed. Use Search.
You can be safer with trailer brakes, or anti-sway hitches. Also discussed.
This is dead (pun intended) wrong - it's backwards. Recommended tongue weight is (towed weight) X 10%. But at 5000#, 500# on the tongue would be a lot for a soft-azz 4R.
If you bolted the hitch to the frame, just above the reciever, to support the extra weight to prevent the Hitch from sagging, then it should be fine. That is basically what was done on the 4th Gen with V8s - 700lbs/7000lbs. Springs, rear drivetrain, were the same as the V6 model. If you modified it properly, the vehicle will be fine.
A lot will disagree, but you'll see that not many people give you warning when you ask how you can install 33" or 35" tires or want to lift your rig 3+ inches!
