HaHa ..I wondered.. I read some vehicles do this I have only owned a 4runner for a month or so. I get so paranoid when I first buy a used vehicle.That's a normal thing that supposed to happen. It's a factory safety feature in which a sensor on the tranny won't let it shift normally until the engine gets up to temp. O/D will not work at all during the warm-up phase. Don't waste your money taking it to a shop (they'll probably tell you it needs a new tranny, haha!). Just let it warm up a few minutes, it's almost winter!
You should still warm up the engine before you take off. It will last longer.
Yep on both count: Normal and let it warm up minimum solid 5 mins. Still running and towing over a ton with original, unrepaired auto tranny at 182k+ miles.
So you are saying I should let my 4runner ideal for 5 mins before I start driving?
Yes, for cool season temperatures below 40F at least 5 mins minimum. I realize not everyone here is a proponent for engine/tranny warm up but it certainly kept my truck healthy. Also if you have not driven your trucks for a few days in any temperature.
My vehicle will idle cold at 1500 rpm. I can let it do that for several minutes, or shift into gear and transfer that energy into forward motion. Think about that.
This is common in pretty much every auto trans. Just the laws of physics again. The seals and valves are not quite sealed until the unit reaches operating temp, goes for engines too. Perfectly normal operation. I wouldn't suggest waiting for the trans to warm up before you drive to work either. That's gonna take a long time rather than the 30 sec it takes while driving. The torque converter makes 90% of the heat in the trans and isn't going to do so unless you driving.
I just wanted to clarify the trans doesn't shift into 3rd at all until it is warm I haven't own a vehicle that has done that before
I like to think of it this way: When it first wakes up, your truck is kinda grumpy. Give it a few minutes to wake up and have its morning coffee (warm up), and it will be much more pleasant to deal with...
Slow to shift, perfectly normal for all the reasons mentioned. Take it easy on the truck and always let it warm up, and you will be rewarded with a very reliable vehicle for a very long time. Abuse it, especially when cold, and you will start to hear expensive noises in relatively short order, "Toyota reliability" or not!
