tranny swap
TacoRunner13
i have an 87 22rte 4R and i want to swap the auto tranny with a 5 speed . my question is will it affect the turbos function ?
great
thanks for the info fellas . although auto trans is a luxury , i really dont mind driving manual. now the next question would be if the same year 4r manual trans will bolt up to my block ?
Any thing that fits a 22r 22re block will bolt to a 22rte. You'll need a crank bearing and to make sure you remove the spacer between the crank and the flywheel. I ran a G52 trans on mine.
No one has mentioned it but you'll also need the correct t-case to go with what ever trans you use, you can't use the one from the auto.
