Tranny Trouble! Won't engage reverse gear
4runner_pr
I have a 97 4cyl with 330,000+ miles on it, and when I run it cold it shifts really high, at around 2500 - 3000 rpm and won't engage the reverse gear unless I drive it for a while and has shifted through all the gears. After that it will engage in reverse just fine as long as I don't brake hard or turn it off. Did a search here on the forum, the oil level is fine, checked the radiator and no problems there either. Has anybody else had this problem, and what was the culprit?
I appreciate any suggestion you guys might have, Thanks!
The cold shift is 100% normal, all of our vehicles do that.
A fluid color check/replacement looks to be in order, it's by far the cheapest potential fix.
2001ATL
