reddi red
hey gang.
i just bought a 1999 3.4 4x4 highlander ed 4runner like 2 months ago.
right now:
the trans is starting to slip......once, when i came to a stop from the hwy, there was a clunk.....like someone hit my truck?? also this morning, came off the hwy, stopped at stop sign, then tried to take off....nothing for about 5 seconds......then it clunked into gear then everything was good.
the truck had new trans fluid when purchased, then 10 days ago, i changed it because of abnormal shifting and noted that the trans fluid was a little too dark, like it had burned or something. shifted ok after drain & fill.
also when checking the fluid, THE DIPSTICK BROKE inside the tube. 1/3 of the dipstick is now stuck in the filler tube.
couldn't make this up!!
also, with the brakes....i think.
from a crawl, once the brakes are depressed, the truck stops abruptly, like i slammed on the brakes. really weird.
now i'm worried about the transfer case too. not sure if it is shifting out of 4x4 properly. sure the 4x4 light goes off, but if in deep turn or if i immediately go into a deep turn, if feels like the 4x4 is still engaged.
when the truck was purchased, it had new trans fluid and a new radiator which recently led me to believe that there could've been a internal rupture resulting in the notorious pink milkshake. dealer says no, but i say yes.
pretty bad after 2 months of ownership and I LOVE THIS TRUCK!!
any thoughts or advice would be greatly appreciated
right now:
