Hi Again~
Im telling you that you ruptured the tranny cooler. The rest of your radiator is more thanlikely fine, but when the tranny cooler line busts it renders the radiator useless.
This was a design flaw by Toyota as far as I and many others are concerned. They incorporated the tranny coller to fit inside of the radiator and not externally like many. So, when the tranny cooler goes, the radiator goes, with the potentialto mess up many other things.
Although its somewhat of a rarity, it has been discussed all too often on this forum, considering it is specific.
Sorry to be blunt, but you should be worried. Your worry is what is whatts going to save your tranny and block.
IKf you have strawberry milk shake in your overflow and inside your radiator, then this is a for sure sign that the tranny cooler has ruptured inside o your radiator, hence th reason you are also seeing this color when you remove the radiator cap. Yes, your fluid was once green, but quickly mixed with ATF when the cooler ruptured, reating a strawberry milskake.
As for a remedy, again, you need to follow the steps I outlined in the prior post.
But, with regard to my personal situation, the baby is running like a charm because I followed those steps and didn't drive the Runner with this mix running through the Tranny and cooling parts for an extended amount of time.
I literally saw the symptoms and pulled it into a nearby shop, where they proceeeded to flush the transmission, (with water more than likey), and flushed the radiator, etc. This is all they are able to do unless you want them to rip the tranny apart and the engine to remove the excess fluid within your block and torque converter(very expensive and not worthwhile).
My suggestions is to flush the tranny once or twice depending on its color after the first time.
You then need to have the radiator flushed a minimum of 2-3 times and ideally you want to NOT be able to see ATF residue in the overflow anymore, this will be your guiding light as to whether you need to continue flushing the cooling system.
Again, the reason you have to keep flushing is because it is near impossible to remove all of your ATF and coolant by just a normal flush that shop does. Those fluid get into the engine and tranny so deep that you literally have to take them apart to remove it or you have to continue running it and flushing it, like I did.
Remember to buy and use the Dr. Tranny, it will re-establish this bond that you will more than likely lose after the tranny gets flushed, especially considering the mileage you have.
Also, you will most definitely have to buy a new radiator. ITs now junk.
The internal rubberpart of your overflow and radiator cap will swell in time and you will more than likely have to replace these.
Total was around $550, not by the dealer. This was a rebuilt radiator.
Hope this helps.
