GenIIIPauly
So what part number did ya end up with? I can certainly go to Camelback, since I live in Florence.....
Reviving this thread as I'm pretty fed up with the dipstick on my 96. I'm assuming that since the markings are at different levels between the years that the tubes are different lengths. I'm wondering if I can pull a dipstick and tube from a 99+ the next time I'm at the junkyard or off ebay. I'm also thinking of just cutting the last 6" or so off my 96 stick since I don't really need the cold markings anyway and it's those last 6" that are the most difficult. Anyone with both versions have thoughts on their interchangeability? I'm really envious of those steel cable dipsticks on a lot of European transmissions.Now that I own a 98 and 00 4runner, I apologize for my previous post. There is a definite difference between the years. My 2000 AT dipstick inserts relatively easy. My 98 on the other hand is a nightmare and requires a lot of force. I even bought a new one thinking the one on the vehicle when I bought it was the wrong one. The new one is just as hard to insert. I have since figured out the optimum insertion position of the dipstick so it will go in without bending, but the dipsticks on the earlier years have been the hardest AT dipstick to insert that I've ever experienced. There's no doubt you need two hands and the right angle to get this dipstick in without bending it or breaking it. Toyota obviously made an improvement for the later years.
I pull one to show you. Basically no bends until the bottom section. Hopefully I remember to pull one a take a photo for you. If some bends in the top that's just PO trying to get the darn thing in.Ok, so I stumbled across this thread after doing some transmission research, and I have a question. How twisted/bent/curved are your dipsticks? I ask because, like all of you, it's a PITA to get in. All my previous vehicles have had a relative flat dipstick, save for a twist here or there, but my 3rd gen is all over the place. Being my first 3rd gen, I dont know if it's normal, or the previous owner ran it over before replacing it.
you are 100% correct and I'm surprised that this thread has 3 pages for something my ten year old figured out on his own when I asked him to put back the dipstickDudes, Dudes, Dudes, Let me give you a class in Transmission Dipstick Insertion 101. Some dipsticks like our engine oil pan dipsticks can be inserted with one hand because it goes in fairly straight. If the dipstick is hard to insert into the dipstick tube due to the bends in the tube, this is when you get your other hand into the procedure. I'm right handed so I hold the trans dipstick handle in my right hand while I feed the dipstick in with my left hand right above the dipstick tube opening. When you try to shove the dipstick in just from the handle, the dipstick wants to bend on you because you have a lot of flexible dipstick between the handle and where that first bend in the dipstick tube is. When you feed the dipstick in by grabbing the actual dipstick a little above the opening, you now are working with a shorter section of dipstick that you're trying to push past the bend in the dipstick tube. The shorter section has more rigidity and thus won't bend or break on you.
There is no reason why you should break the trans dipstick. This is operator error.
The dipstick on my '97 was getting bent over time because it required so much force to insert it that I didn't trust the readings on it. When I replaced my trans pan last year due to the threads on the drain being stripped, I decided to go all out and get a new pan, upper tube, and dipstick.
What a mistake. I needed the new pan, but it went from 'difficult to insert and requiring a lot of force' to 'it just won't go in at all after a certain point.' And yes, I tried rotating it 90*, etc, etc. Really buttered my beans to have gotten all new OEM parts and made the situation worse.
I was at my buddy's shop when I put the parts on and he was getting a chuckle out of it, "how hard could it be, let me show you how to do that" and he quickly changed his tune once he tried it. This is a lifetime mechanic who I've never seen get stumped by anything before. Ultimately he just handed me a full length piece of tig filler wire and said to put some little marks on it that line up with the marks on the dipstick.
That's what I do now, I snipped off the bent portion of the original dipstick and just use that as a plug for the dipstick tube. I use the new dipstick as a reference, and the tig wire as the dipstick. It's really not optimal, but it works. I'm glad to hear they revised the design on later years.
I still hate just how stiff it is to put the stupid thing in, it is actually so bad that I refrain from checking it unless I am at home. I just had an idea after hearing about you using tig wire to check the height. Would it slide in easier if we narrowed down one of the sides on the bottom 8-10 inches of the dipstick? I will take one from a 4Runner the next time I go to the junkyard and try this out.
