cj80cruiser
Senior Member
I read the step by step instrutions on how to drop the pan, change the filter, reseal the pan, and then flush the transmission but I don't want to go that far. I'm just looking to drain about 4 quarts by removing the trasmission cooler return line and pumping 1 quart out at a time until I have removed the 4 quarts.
Has anyone done it this way before? I've heard not to flush an older tranny.
What brand ATF would you get if not getting OEM...I'm looking at semi-synthetic Lucas ATF. I guess that would be fine to mix with my old ATF?
