Transmission Fluid
ozzy4355
Member
Any one know where the dipstick is for the transmission fluid on an 04 SR5 V8. Also how often should the transmission fluid be flushed and filled.
04 and up T4R's have a "sealed" transmission, meaning there is no dipstick to check. They also say that the fluid is lifetime but you can still get the fluid drained and filled but I personally would recommend staying away from flushing the fluid, it can cause a lot of problems. I try to get mine drained and filled about every 30k.
Tranny fluid changes should be based on driving conditions. Stop and go, frequent stops vs. highway, towing, etc...
How did you drain and fill the tranny?
how many quarts would be required to refill the transmission fluid reservoir after a drain? I'm considering doing a Royal Purple ATF refill and would like to know how many quarts to order. Thanks
There are 15 quarts in the system, but only 3.5 quarts will drain through the plug. So actually, unless you do the flush method, you are only changing about 20% of the fluid when you drain and fill.
Toyota is known for its durability and engineering. There is a tranny temp sensor and dash light in the event the unit is working too hard. Unless it is really bothering you, I would run it for at least 75K and then do a flush.
JMHO
Thanks ALLEGRO; I have 62k miles on my Runner now and i'll probably hold off until 70k for a flush with RP.
