Transmission flush or drain?
Just drain and refill. Maybe a few months later drain and refill again. This will allow you to get much of the old fluid out.
Soooooo ...
Just curious. All you folks doing these fluid changes at home, what are you doing with the old fluids? I'm reading of up to 4 gallons of ATF needing to be disposed of in some cases.
I do all my own oil changes because I can take all my waste oil to the recycling center but I know of no place where I can take ATF or other vehicle waste fluids without paying $$$'s in disposal fees.
What are you guys doing? (not sure I want to know)
Soooooo ...
most dealerships should take the other fluids as well.
The recycling center out here takes it all, petroleum based or not, if you're a customer and bring it in yourself. There are volume limits but they're pretty generous.
FYI all Jiffy Lube locations will take any motor vehicle fluid except gasoline/diesel fuel.
I have dropped off used motor oil, gear oil, ATF, P/S and brake fluid. Every time they have even come out to my truck and taken away for me (I have the jugs of used stuff boxed up).
This is untrue, Toyota states that the WS Fluid is "lifetime fluid," but if you look at your owner's manual and Toyota's service information, the fluid must be changed at 60k if you do towing or use and then goes on a 30k interval for flushes.
I've stated many times in multiple other threads my disbelief in anything labeled as "lifetime fluid" especially transmission fluids. For those of us driving normally or moderately in our 4Runners a 100k flush & fill is probably a good idea. Our dealership even recommends it as a service item around that mileage.
Toyota like other manufactuers who use these "magical lifetime fluids" have conflicting literature in there service information. For example:
T-SB-0006-11
States in one line; World Standard (WS) Automatic Transmission Fluid (ATF) was introduced to reduce maintenance costs and increase the mileage between scheduled maintenance checks. Here are some important tips when working with ATF-WS in Toyota vehicles requiring its use.
Yet further in the TSB it also states; 100,000 Mile Maintenance Interval - Inspection only; ATF-WS does NOT require any flushing or changing during the life of the vehicle.
How would they flush it if it's sealed? Do they take the whole panel off? Like on older model cars, truck you have a entrance port for transmission fluid and an exit plug like for oil. I have not seen things. I don't tow that much. I once towed a 5000lb excavator and a trailer with a bike at one point also 2000lb of cement mix twice. But over all 95% of the time I owned the Runner it's been a mix of highway and regular road driving.
Flushing is usually done from the tranny cooler lines. Also "Sealed" doesn't really mean sealed. There are drain and fill holes/bolts/port just no dip stick.
Toyota specifically states to do a Drain & Refill, not a flush on any of our "sealed" transmission as do the manufacturer's of the flush machinery.
There is a drain & "level indicator port" on the bottom of the transmission, you drain the fluid out and them pump in WS Fluid usually by a hand pump like you would a manual trans or differential. Then you bring the trans to a specific operating temperature and check the drip tube for fluid flow... Its pointlessly over complicated, but there is a procedure and many members have posted the information before.
Great to know ! Is this true even if you don't have any work done there ?
I have never had any work done at any Jiffy Lube but my local one knows me pretty well from all the fluids i bring in. They are usually more than happy to take it all.
I have 2009 T4R V6 4WD with about 55000 miles. When I contacted my local dealer to get an idea of how much it would cost, they quoted me $75 for drain and fill but recommends a flush to replace all fluid. The cost for flush is $152.
I am curious what's the source for "Toyota specifically states to do a Drain & Refill, not a flush" on our vehicle? As they recommended flush for me?
I had my Toyota dealer do a complete fluid exchange on my 2007 V8 Limited @90K. I had them use my AMSOIL fluid. All fluid was exchanged and there have been no issues. I would recommend having it done at the dealer.
Resurrecting an old thread, as I wasn't quite sure if the answer was directed to me. But I have an 2006 V-6 with now 85k miles. There is no previous owner paperwork/trail showing that they did anything with transmission fluid and such. I called the dealership even after mentioning the possibility of "shocking" the system, and doing a drain and fill instead, they said they would do a flush for $240+tax. If I am reading correctly would you guys all advise against that, and just do a drain and fill on my own? I want to do this soon as it worries me not knowing what the previous owner did or did not do and I have a trip in Colorado coming up in the next couple of months that I would like to be worry free.
Thanks in advance!
-nick
Thanks for resurfacing this thread. It's comming up to four years on the 'Runner (only 25,000 km) but it's getting close for a tranny service. Has anyone acutally done an old-school drain and refill on a non-dipstick 4Runner? Meaning, draining what's in the sump and re-filling through the hole (like changing the oil on a diff?). All the Alfred Nobels out there, stop now; yeah, we know it dosen't get all the fluid out of the transmission (converter, etc.) but I hate going to the the dealer and godferbid a corner garage. A few old-school changes over a few years is still the best and least invasive option IMO, using WS or equivalent fluid of course.
Lots of corner garages like to give you the BG chemical flush machine treatment. Moneymaker for them and some risk for you if the trans is old enough and if they do not manage the refill properly (it can be tricky).
Good thread. I just picked up a 2004 V8 with 105,000 on the clock. Toyota owners' website shows that at 97,000 or so, the previous owner had a full service done on this vehicle. The technician put into the system that the transmission fluid was part of the service...however, in the parts and materials list that's on the website it does not show any transmission fluid being used. There's a big list of fluids and filters, etc. but no trans. fluid shows up. So now I have no idea whether the trans. was serviced in this one or not.
I don't know what to do. If I do drain and refill...I'd have to do it multiple times to get all the old stuff out which is a PITA. If I pay for a flush I'm risking having problems. If I do nothing at all I'm risking having problems. Argh!!!!!
If you're intent on getting all the old stuff out, you have no choice.
My perspective, based on regular reading of this forum for 8 years, is that the two drain and fills I did at 100k plus the one or two I will do every 50,000 from here on out will let this transmission live forever.
I assume you have the sealed trans (no dipstick) with the synthetic lifetime fluid.
Make sure that you get an accurate definition of what they mean by "flush" a lot of guys (myself included) will use drain & fill and flush interchangeably for the process of emptying the fluid pan and refilling the trans multiple times.
Toyota has come out as well as a few of the manufacturers of the transmission flushing machines and said they DO NOT want you to machine their sealed (WS Fluid Using) transmissions and transaxles as it could cause damage. The proper method is to drain and fill (the service literature says one to two times, but I recommend until the majority of the fluid is close in color and consistency of the new fluid, usually 3-4 flushes)
If you have a Sealed Transmission ('04+ for V8's and '05-ish+ V6's) you will need to do a drain and fill. If you have a dipstick (non-sealed) it takes T-IV ATF and can be flushed by a machine.
OK I'll just drain it and put fluid back in. So the pan holds about 3 quarts? And what about the drain plug? Does it require a new crush washer?
