Transmission oil drain and fill
I see a lot of threads recommending only a drain and flush for the transmission.
Just to clear things up, do you drain from the oil pan? Do you do this only once?
I used a hand pump and pumped out 2 qts of transmission oil from the dip stick tube and poured in Dextron III oil from the same tube. The spec sheet says it contains 2.1 qts in the oil pan, however it also says the transmission holds 10 qts of oil total. This means I only replaced 20% of the transmission oil. Should I do multiple drain and fills? How much should I replace?
For background purposes, I have a 2000 4runner with 76k on it and I'm just trying to do some preventative maintenance. I believe a flush/fill was done at 60k by a shop. I only realized (remembered) that I may have done this when the old fluid that came out was just dark red.
