Transmission pan drain bolt stripped! :(
quicksilvr
When I was taking the drain bolt out of the trans pan on the '97, it felt tight. I got a bad feeling in my stomach. Once it was out, I could see that one of the threads was tweaked pretty good. I bought a new drain plug bolt....hoping that a non-boogered bolt would go in pretty smooth and seal it up.
But alas! The new bolt stripped out the pan. I can't even get it tight enough for it to not leak! It's a slow leak, but still. I also can't get the it to bite enough to come OUT!
What are my options fella's? New trans pan? New oversize bolt if I can figure out how to get it out?
Get a thread gauge, avail at any parts store. Figure out the thread and bolt size, buy a tap and re-tap the pan. I would do this with the pan OFF! That way you can make sure you get any metal out of the pan from re-tapping the hole. Then I would buy a new plug. An over sized bolt wont thread in the existing threads/hole.
Heli-coil, or even better, Time-Sert.
That's if tapping the existing threads doesn't work.
Is there enough room in the thick area where the plug is to drill out for heli-coil? I honestly dont know. I have a 4th gen.
If it were me I'd call local wrecking yards and get a new pan. Most fixes for that are never perfect really... I'm sure you could probably find someone parting out a car and pick up the pan for cheap.
Agree on a new/used pan. You'd have to remove it to fix it anyway. $87 from toyotapartseast.com . Might as well change the filter while you're in there (if you haven't done it lately).
I'm going to get a new pan. It's easy enough to take off, and I hate doing things half-ass. Even though I'm just selling the rig, I want it 100%.
Weld it shut. Call it a day. Ive seen too many really, really bad filters from people just doing a drain and fill over and over. Very few autos even have drain plugs. I hear ya on wantin everything 100% though... Just had a long day with a bunch of crazy customers and their crazy cars.
