DoctorJest
I'm hoping someone'll be able to give me some tips on this. Our '95 4Runner has an issue where it'll occasionally slip; you'll lose power for a moment, then it'll come back and all will be well. It doesn't happen always; I'd say maybe one trip out in every two or three. It also only seems to happen in what I'd guess is the second gear in the automatic transmission.
It did the same thing today, slipping, but then it seemed to settle in neutral after that, as if it had become confused while switching gears; after we parked up and started up again, though, it behaved perfectly normally and got us where we were going (and, blessedly, back home again afterwards).
I've recently used an additive in my power-steering tank, something that's supposed soften and expand the seals to fix a leak; it seems to have worked a charm on the PS leak, but I noticed on the bottle that it also says it can help to fix transmission slip that is caused by gear polishing; I'm wondering if anyone else has had this problem, and whether anyone knows enough to say whether or not this sounds like it could help?
(Also -- honestly, if it comes down to replacing the transmission, I may try this bottle on the transmission first anyway. It costs about $12, and if I'm going to have to shell out for a whole transmission, then that's a fairly negligible expense...)
