transmission troubles?
avenged yoda
alright im freaking out and i need yalls advice. every couple days or so my truck will act like it doesnt want to shift. or ill just be cruising along like 45 miles an hour and itll down shift and rev up and not want to shift back up to the next gear. or it will go back and forth like that. usually i pull over and turn the truck off and then wait a sec then turn it back on and itll stop. i had the tranny flushed when i first got the truck about 3 months ago. i was thinking maybe my shifter is either to far foward toward neutral or to far down toward 2nd. idk if that could have anything to do with it but just seems like when i pay close attention to that it doesnt do it so yea.
It's not fluid. If the fluid was low it would always below and certainly not after you had been driving and it built pressure. It's electrical. One of the solenoids is on the way out. Not a biggie, just have to track it down. Any CEL's or codes?
none at all. but thanks for the lead i will def look into it! and it wasnt the fluid.
charlesz
