That's the same seller I bought mine from too. They're very good quality, each letter is an individual sticker unlike the OEM ones, but IMO they look way better because you don't have the edge of the clear sticker like the OEMs. If you're thinking about getting them, you don't have to worry about the letters peeling up either, they're stuck on there good!
Thanks for the comments guys. The stickers from that seller come with little instructions that make it easy to apply. I probably would have botched it up real good if i didn't use the tape method like the instructions call for.
How did you apply them? I used the windex/soapy water method which allows about 10 minutes to get them in place,push out as many of the air bubbles as possible and then let set.
that looks good! i have black also, but i wanted to find a sticker color that would match! i got an idea now from you....however i have chrome bumpers so i donno how that would look.....
Ya just cut it down the center with a razor blade for the gas door.
As for application I just cleaned it with glass cleaner and let it dry. I used 2 small peices of masking tape on each side to get it set and level and stuff, then I put a strip of tape along the top of the sticker all the way across.
Then I lifted it up like a flap and took the backing off the sticker and CAREFULLY started using the spatula to press it down starting from one corner while pulling lightly down and away from the truck a little on the opposite corner to keep the sticker taught. Then I peeled off the outer paper cover thing at a 180 degree angle (basically folding it over itself and pulling it back).
The letters are small enough that bubbles didn't seem to be an issue. If there are any bubbles just chase them to where there is no letters, you don't even need to get them all the way out...
I didn't know about the soapy water/windex method...maybe that is easier, IDK.
nice i like to red over black, i got the black and silver ones for mine, sucks i put my driver side one on a little crooked because they really are stuck when you stick em haha
Dealers charge almost $100/pair so if you can get two for under $40 then it's a steal plus when I got mine I got the two stickers plus I got three small TRD stickers with it.
Yea I guess 2 for 37 bucks aint bad but it is a bit for stickers man. I found a guy on ebay and for 15 bucks got 2 stickers for my rear fenders. Some people are rightfully skeptical when it comes to knock offs but these are STICKERS not cell phones or watches or something. Anyhow, they are IDENTICAL to factory and theyre di-cut/computer cut so they dont have the clear film surrounding like factory ones do. I think they actually look better. I'll get some pics up soon. 15 bucks man!!!! And he has different color options! Take a browse on ebay for trd decals and you'll see....
