TRD PRO Behind the grill light bar
BurlingameT4R
what do you guy think ?
i like it. Id like to add additional lights up front on my 2010 but the front grill bars that are available dont look good to me..
they are Hella 500FF (7") , gift from my wife "years" ago that i was planned to put on my 4th Gen 4runner but sold.
i wish they are smaller but i don't think the 1" blocked by the grill on top would make a diff
out of curiosity what size are those 7 or 9 inch?
those lights were suppose to go on this bad boy ( i still miss it )
I think they look like they are a bit large for the area
*Edit: I walked away while typing a response, I see OP mentioned the same - Smaller would better suit the space (said no man, ever)
its definitely refreshing to see something different. I wonder if 6 inchers would fit better.
true that , i may get by using that until i can swap out with something else .
at least now i can tell "her" i am using the gift, so keep it coming ..... :humble:
I put this one behind the upper grill on my 2010. If you remove the 2 outside plastic fasteners you can use the included mounts through those holes, although it's tight. I installed it before setting up wiring into the cab, so I only tested it briefly wired directly to the Blue Sea fuse block, but it was certainly very bright. We'll see how it holds up given the cheap price (my normal tactic is to buy cheap at first, and then upgrade if it doesn't work out).
Can you share some pics? Sounds interesting..
I seem to only have this one so far of the lightbar itself. I took some others while wiring it up that I'll eventually put into a build thread.
Image.
Installed this light bar behind the grill with the rago brackets
