TRD Pro Lean?
rasber3140
I have just cleared 10K on my 2017 TRD Pro 4Runner. In looking at it the other day it appeared that it was lower on the rear drivers side. After measuring the rear it is about .5 inches lower on the rear drivers side from the passenger side. This was measured on an empty tank with no one sitting inside. Anyone else experience this?
Sounds like the normal "driver's side lean" to me due to the battery, driver, and fuel tank offset to that side. Did you measure the front too?
Did you put your 1" Toytec spring seats on the 'stock' clip positions, or was the position changed during install?
Can we all come to some consensus that all 5th Gen 4Runners - KDSS, non-KDSS, SR5 to TRD PRO - they all lean? And if we all pull together we can convince ourselves, collectively, that this inherent lean is cool... and actually desirable.. even coveted? :)
limited time only!
