hmmm........well my google search brough it up first try?!? Here ya go, try to do your own research next time.
Qty Description Connection or Installation Location Page Part Number
1 Supercharger/Manifold Assembly Main Assembly - Bolts directly to Factory Manifold 11 00602-17620-207
1 Supercharger Belt Replaces Factory Alternator Belt 12-13 00602-17620-026
1 Assembly, Tensioner Plate and Pulley Installed on front of engine 10 00602-17620-082*
1 Kit, Dynamic Tensioner Plate Installation Hardware 9 00602-17620-090
1 Dynamic Tensioner Plate Installed on front of engine 9 00602-17620-015P-4
1 Bolt, 10 x 1.25 X 70mm Flat Head Bolt Hole A 10
1 Bolt, 10 x 1.25 X 135mm Hex Head Bolt Hole B 10
1 Washer, 10mm Flat Bolt Hole C 10
1 Wiring Loom Relocation Bracket Installed on front of engine 9 00602-17620-077
1 Dipstick Relocation Bracket Installed on front of engine 10 00602-17620-078
1 6 X 10 X 12mm Bolt Dipstick relocation bracket 10
1 6mm Flat Washer Dipstick relocation bracket 10
1 Kit, Literature
1 Manual, 3.4 Installation - Revision B 00602-05100-221
1 Gasket, 3.4 S/C Throttle Body Between Factory Throttle Body and TRD Supercharger 14 00602-17620-032
1 EO Sticker Place underneath hood 15
1 Warranty Card (Fill out and send to TRD) ** WARNING POTENTIAL LOSS OF WARRANTY ** see inside covers
1 Warranty Certificate Keep in red envelope, in glove compartment -
1 Hanger, Mirror SC Noise Warning Makes customers aware of Roots-type supercharger whine - 00602-05100-045
1 Sticker, TRD Sport Parts Place as desired on external surfaces of vehicle - 05100-SP100
1 Decal, Supercharger Place as desired. Usually placed on Factory Timing Belt Cover - 00602-17620-042
1 Template for Cutting Front Cover Use to modify Factory Timing Belt Cover 8 00602-17620-2TP
1 Belt Routing Sticker Under hood 15
1 Premium Fuel Sticker Place one on or near fuel gauge, the other inside fuel filler door 15
3 Set, TRD S/C Emblems Place as desired on external surfaces of vehicle 15 00602-17620-SCE
Supercharger Brochure, Catalogs, Promo. Matl. -
1 Hose, Connector and Hardware Kit
1 1/8
