TrekLights LED Light Bar Group Buy
TrekLights, do you have any non-6000k light bars?
I would prefer nature yellow for the trails.
Hey Brian I've been doing a butt-load of research on LED bars lately and there are none (that I am aware of anyways..) that have 4300k LED's. I'm not sure why this is either but it might have something to do with the drivers and maybe LED's do better at a slighter higher Kelvin than HID's or Halogens in terms of bulb life? I have seen some 5000k bars and that was it.
FWIW - even the "expensive" bars from Rigid and Vision X are in the 5500-6000K range.
Hopefully Troy can shed some light of his own, but I'm assuming there is a reason other than "it looks cool" behind the color temp. of all of these LED bars.
I seem to remember that the rigid lights Dually D2s that Dirtco is running are expensive but amber.
Thanks for filling in for me, guys. Dropped my phone into the ocean when I was in Maine on Monday and I don't have access to my emails at work.
As of today, all of our LED's are in the 5500K - 6000K range. The CREE's are going to be closer to the lower number.
Hate to say it, but your best bet for amber or yellow lighting would be either an offering from Rigid, or an adhesive backed amber vinyl over the lens of one of our light bars.
I may be interested in the 22" or 33" ES. Would have to check measurements. But for just getting one on the front end would you suggest a spot or a flood pattern?
Here you can see the savage power of the 36" TrekLight XT in Spot Pattern.
In the last two photos, you can see the mounts and the brackets. The mounts slide along that rail, and you attach that tilt bracket to the mount and bolt down the bracket. A very cool system.
How am I going to buy anything if you keep making new products, I dont do well with options. :dizzy:
Is the top flood and bottom spot?
What are the specs- lumens, 3 watt Cree.....
Just kidden about the new products, keep them coming. There is always more money for more stuff right?
Check out this little beauty I've been testing ;)
Flood beam on the top half, spot beam on the bottom half.
This one is 12"W x 5"H x 3.5"D
Add 1.5" to the height for the mounting bracket.
12,000 Lumens
3 Watt CREE LED's
Also available in 6", 9", and 17".
This one is $479 retail, $439 with the t4r.org discount
I am glad I dont live across the street from you :) :) :)
12,000 Lumens
3 Watt CREE LED's
