RussToy
Each light is shipping with a switch and a fuse holder. Relay and wire gauge is up to your personal preferences.
Yes, those switches should work. I've had my eye on the Zombie Lights version for a while now
If anyone is looking for a pre-built harness, I recommend this one: Low Beam: 9006/HB4 - Relay Harnesses from The Retrofit Source Inc
Paired with these (or similar) connectors: 9006 Female Wire Harness Connector Plugs Hella Ballast | eBay
Hello Sir,
I've been looking at your lights and like what I see. I have a question about the wiring set up...I looked at the links you posted above. So, are you saying...the e-bay connectors will plug into your lights...then you connect the retrofit harness
to the e-bay set up? Will all the plugs plug into each other for a factory look? Or do you need other connects? If so, where do you get them from? Or, do I back that backwards? Thanks for your time...
Russel
