Tru Trac LSD in a 3rd Gen (Front Diff)
Duhockey
Senior Member
Ok, so I know FoneRunner and LINY4runner have already done this, but I ran into some problems.
I dont want anyone else having these problems so heres the deal.
After I blew my spider gears in my front diff, I decided I wanted to go the same route as FoneRunner and LINY.
I started looking at lockers and decided on the same Detroit/Eaton Tru-Trac LSD that they had. I never saw them post any part #'s so I went to 4wheelparts (dont use them EVER) and then SummitRacing.com and used their vehicle selectors to choose the right locker. Both came up with the same part # DTL-911A445
I have since found out that almost every supplier when looking in their system will give you DTL-911A445, (at least initially) some suppliers upon looking have notes somewhere in their system alerting them of the change but very few mentioned anything.
This is incorrect. DTL-911A445 is for the 85-95 4 cyl. There is still confusion as to whether that part # will work with straight axle or only with IFS.
The correct part # for the 96-up V6 WAS DTL-911A342 which has since been replaced with DTL-911A644... This is part # you want to order for the V6 3rd Gen.
The guys at East Coast Gear Supply sell the correct part for 470$
4wheel parts charges 514$ and the SummitRacing.com quoted me 508$
It sounds like Eaton/Detroit mixed up the part #'s when giving them to all their distributers.
Even ECGS' supplier has the wrong part # listed for the V6 3rd gens.
luckily, Ryan and Chase from ECGS knew the correct part # in their head.
ECGS website does not currently list this part, but if you want a Trutrac LSD, I highly recommend you call them and get this part from them along with the Master Rebuild kits and any other gears you might be doing in the process... If I had ordered everything from them from the start i would have been done with this a month ago.
oh,
the actual problem with the DTL-911A445 is that Carrier bearings are too small to hold the carrier in place. The Pinion bearings are just fine but the Carrier ones are too small.
I asked the guys at ECGS if there were different bearings I could go with but that was a negative. You need the correct TruTrac to fit correctly with the stock bearing set.
figured some people might want to know why that part # wouldnt work.
Sorry to hear that's the case Shon. Hopefully you were able to return it as the mistake was theirs. Do you have the right unit now?
Luckily Summit Racing sent UPS to pick up the wrong locker today.
I bought the correct one from ECGS and its on its way. Again, a reminder that ECGS does not list TruTracs as available on their website but they DO have them. and they are cheaper than anywhere else Ive called.
