Truck dies overnight
Rambler808
As of now my truck doesn't start about 60% of the time, my starter engages but has a constant whining sound and nothing else happens instead of that throaty cough before it would usually turn over. I got a new battery through warranty and had my alternator tested and they're both perfectly fine. I thought it might be my starter but it works when it hasn't sat for very long and it starts right away with a jump. It's as if I have a power leak but I don't know what to do :frusty:
insert a 12v test light between the battery negative terminal and the ground cable. if you have a drain, it will light.
remove fuses one at a time until the light goes out. that circuit has your drain.
thanks for that I have a drain too and need to isolate it but that is a cool trick for finding a drain in the first place.
I believe the whine you hear is the starter trying to engage - not engaging. Only two things I know can cause this. The battery does not have enough power to both engage the starter and turn the flywheel; or the starter is bad. If the battery is good you could still have a bad + battery cable to the starter. Over time the cable can corrode resulting in not enough power making it to the starter. Bad or loose ground cable can also cause issues.
bobdjr41
