Truck leaning to one side
Satter
Okay, my 4R is leaning lower on the driver's side and it's aggrevating the @#$% outta me. I brought it in about 2 months ago to the dealership and they said I needed to struts in front. So, not only did I get new struts, but I had them put new coils and struts on both front tires. It fixed it, and looked just about level for a while. Now, it's sagging to the side again. When I bring it in this weekend what should I have them look for?
I had the same problem but was a bent sway bar link. Easily visible if you turn the wheels to the passenger side and take a gander. It will be quite obvious and a cheap fix.
Make sure that when they put in the new coils that the drivers side is higher, Toyota made their coils this way from the factory to compensate for the gas tank weight because the entire thing is on the drivers side.
