Trying to pull ABS fuse !
kennyb3030
got the fuse panel unscrewed and then i flip it over to unscrew the abs fuse and there is nothing to unscrew coming in from the bottom. only way i see to unscrew the fuse is going down from the top. everything i read around here says unscrew the fuse box and unscrew the abs fuse from the bottom, what am i doing wrong ?
mine unbolted from the sides of the fuse. one is on the front (pointing to the bumper) and one is on the back side (pointing to the driver) they are 8mm i believe
If u look carefully the box is actually 2 pieces, there should be 4 lil plastic keeper tabs and the inside piece will lift out of the part bolted down. At least that is what i found on my 2000. The tabs are a pita to get all 4 but once i did i realized i didnt even need to unbolt the box from the bay.
