Tsubakimoto timing chain kits
Sidney
I recently purchased a Tsubakimoto timing chain kit for the 22R-E engines used in 1985-95 4-Runners and pickups (also on 1985 Celicas) that has single row timing chain with 96 links for $97 CDN with free shipping.
Anyone have opinions on their quality?,here are the sources to buy them:
Some OEM parts sold aftermarket including Tsubakimoto timing gear kits:
http://www.rockauto.com
http://www.autopartsonlinecanada.com
http://www.autopartsway.ca (1-866-530-5789) (Tsubakimoto timing gear kit, supplied by World Pac 1-800-888-9982)
http://www.autopartsway.com (Tsubakimoto timing gear kit, supplied by World Pac 1-800-888-9982)
http://www.autopartswarehouse.com
I have found these places below to have the best prices on OEM and excellent quality aftermarket parts:
Toyota dealerships selling parts for 20-30% off Toyota's MSRP in USA:
http://www.1sttoyotaparts.com/partscat.html (10% shipping by Fed Ex or free shipping with $100 & over speak to Don 1-888-271-3948)
http://www.toyotapartsales.com (1-866-221-4696)
http://www.toyotadiscountparts.com (free shipping with $200 & up)
http://www.toyotapartsandservice.com (part # lookup)
http://www.toyotaownersonline.com/pub-share/pdf/appchart_sparkplugs06.pdf
I provided the info below to share with others so you members can save money:
OEM Toyota parts sold aftermarket:
http://www.densoaftermarket.com
http://www.densoproducts.com
http://www.sparkplugs.com
http://www.ngksparkplugs.com (use coupon code "dodgetalk" to get extra 10% off)
The best brand of aftermarket timing chain parts to use on the 20R & 22R series Toyota motors are:
http://www.engnbldr.com
http://www.22r.biz
http://www.mizumoauto.com
http://www.rpmrons.com/toyotatiming.html
Sidney
timing chain disaster
When I bought my 4runner the timing chain was already making noise. I drove it for a couple of months which was a mistake.
It turns out that the previous owner had a timing kit installed at some point that included plastic chain guides and all around cheap parts. Plastic guides aren't good because the drivers side guide tends to break which is what happened.
When the guide breaks it falls down into the oil pan and then the chain starts to rub/smack against the side of the timing cover. Eventually it will wear a hole right through the timing cover into the water pump inlet or the impact from the chain on the timing cover will break the seal where the timing cover gasket meets the engine which is what happened to mine.
When the seal goes you end up with a huge mess. coolant and oil was leaking all over the place and coolant was getting into the oil and vice versa.
Hey Sidney,
Have you ever considered starting your own little website? The reason I ask this is because you seem to have alot of information with a ton of different links to all sorts of sites related to 4Runners. This is based on the threads I've seen you contribute to on this forum, your posts always have a ton of usefull information and links.
Just a suggestion I guess...
Thanks for the links
Red said:
Hey Sidney,
No I haven't because I don't know anything computers but if you could show me how and where to get free webspace and bandwidth then I would be glad to share my info with the world.
:cool:
Sidney
Timing kit
I should tell you about this even though you already bought a kit.
I ended up buying a timing kit from engnbldr on ebay. He also sells kits from his own site but they seem to be cheaper on ebay. I noticed you listed him as one of the sources and I'd recommend him.
www.engnbldr.com
The kit I bought included all of the timing parts including a metal backed drivers side guide, a pre-stretched chain, japanese tensioner. I also got a new timing cover, oil pump and water pump. He also answered my questions promptly.
The crazy thing was that I got it all for $160. Most timing kits alone that have a metal guide cost that much.
ian2328
