Tundra front spring height??
deves2
I'm trying to compare the Tundra front spring with some OME (old man emu) springs and would like to know the actual height of the Tundra spring. And on a long shot the weight of the spring (the load capacity)
and if possible what it the OME equivalent to the Tundra fronts
Tks
Dave
I assume you're wanting the height & compression of the TRD spring? Or are you wanting an OE spring dimensions?
Speedys Garage did that lift with the tundra coils and it paired will with the OME 906 rear springs (2 inch lift), so I am assuming they provide a 1.5-2 inch lift. The spring rate is right around 500 lbs I believe. I'd put the tundra coils between the OME 880 and 881.
