Tundra Rims??
WillK
Hey Guys, I got the dumbest question ever, but will 2001-2006 Tundra rims fit on my 2001....???
I know the tires on them are the same size, but not sure of the bolt pattern.
Not sure of which type they are, but here's what they look like.
Not sure about those. You'd have to check the offset. They may have a larger offset than stock, which will make them sit in closer to the body. You can have troubles with the tires hitting the UCA sometimes unless you use a wheel spacer.
But if they are from an 01-06, just like the ones I'm talking about, then you should be fine.
