Tune up parts
Supra725
Well guys and girls..
Tax return is coming up and I figure why not spend some money on my runner.
Here is a couple of things I'm planning on doing.
Re-do the suspension
-Blisten's shocks and new Coil springs
-New Spark Plugs and o2 sensors.
-New diff fluid(What should I run? Mobil 1? Amsoil? and what weight)
-New belts..
-New fuel filter and water pump??
Any other things? I got new rotors, pads and new Atf fluid in her around the 200k mark + or -. the last time I had it in the stealership was the `160k tune up and I'm at 213k right now..
thanks.
as long as you stay with oem parts you should be fine as far as diff fuilds go i useed red line 75w90 in mine
If you do WP, you should consider thermostat as well. I assume TB is one of the 'belts' you had planned.
Also PCV valve is cheap and easy.
Don't neglect those rear brakes. Clean,grease (especially those GD bellcranks) and adjust, plus checking shoes for wear and axle seals for leaks. I just did it and made a HUGE difference in both regular and e-braking (one bellcrank was seized).
Plug wires, if original.
How long since you flushed brake fluid? Two years is a good time period. If it has been since the dealer, you are due.
Then you should be good until next plug change.
Definitely don't cheap out on the cooling system.....you might want to consider new ignition wires if yours are still original.
