So I am not sure if this is the correct forum, but I couldnt find a forced induction forum.
I am looking at the cx racing kit here
cxracing.com: CXRacing Turbo Kit Manifold Downpipe for 95-04 Tacoma 5VZFE 5VZ-FE 5VZ
i want to pick up my own turbo, hopefully used on craigs or other forums,
but I havent a clue exactly what I need. I know i need t4 flange, the "gt35" listed with the kit I have heard likely has a little too slow of a spool to fit with the 4runner use. it should spool around 3k.
I am looking for closer to 2200-2500 k spool. I am ok with giving up some top end and extreme power as 300+ hp is more than sufficient for this truck and what I do in in. but 3k spool for towing sounds like a chore.
a the same time I dont want the power to fall on its face at 5k rpm.
I understand all the mechanicals of turbo charging, but the a/r ratios are dumbfounding to me.
please help. I have seen a few on craigs. but they all seem directed at extreme high hp numbers and high rpm drag cars.
1996 - 5speed trans, 4x4, 3.4.
thanks in advance.
thanks in advance.
