Turn Signal Light Removal on 2005 Question
bigwalts4runner
I was noticing today that the drivers side turn signal light on my 2005 4Runner is all fogged up, and has moisture inside of it. I want to replace it, but I cant see how I would do it; does the whole front bumper have to come off to replace this light, or is there an easier way?
Is the '05 different from my '03? I popped my rear fog lens out and compared it to my front turn lens, it appears to be exactly the same mold and mount, which tell me I should use the same socket to make it a working light. The rear came out easily with one nut, looks like the front would come out the same. One nut comes off, and the light pivots forward and out.
If you're going to clean it, use distilled water, blast that out with air and a hairdryer, then rinse with alcohol and dry.
The whole front bumper to take one light Marker off, thats crazy! The Diagram shows a 2006 and up model, is it the same thing for a 2005 model? My Turn Signal Markers are on the bottom of the bumper.
See if you can get access to it from underneath behind the bumper.
The foglight on the '06 is accessible from underneath, I would imagine it being something similar for your turn signal.
For '05
Turnsignal.jpg~original
