NoDak said:if you want to see a 04 sport v8 w/o DRL, just look at my avatar or my pics. all the pics where taken with the truck running. personally, i dont care for DRL lights that toyota implements.
I was doing that but turning on the headlamps dims the indicator lights on the cabin temperature controls so that I can not see them.but then I leave my lights on 24/7 so I don't really care anymore
sharp4runr said:They turn off after 30 seconds when you leave the car, or if you hit the lock button twice they turn off....
My keyless entry system will turn off the lights when I press the lock button twice. I don't have any alarm system, just the theft deterrent system (transponder keys) and keyless entry.I read in the alarm manual that hitting the lock button twice turns off the headlights,
Mark86 said:The lights will not turn off automatically or with the key if you put the lights on after turning off the engine. A couple of weeks ago I accidently shut off my lights so I turned them on after the engine was off. I went to close them with the key and the lights just stayed on. I then went into the car and turned the key to the one position and then tried again and it worked. The lights have to be turned on either before of while the engine is on or the key is turned to the on position.
When all doors are closed after opening some or all of them after the Ignition SW is turned from ON to OFF with the head and tail lamps ON, these lamps will remain ON for 30 seconds after the doors are closed and then go OUT automatically. Pressing the lock SW on a wireless controller twice in succession turns OFF the lamps instantly.
