brockeverly
Search is your friend, I know, I did.
First, I am ordering the FJ3-FRCC kit from Toytec with the diff drop and no top plate spacers. I will be using stock shocks. With the OME 884s will I need a spacer to fix the lean? If so, do I do the Toytec spacer or the OME trim packer?
Second, those of you with 3" lifts, could someone measure from the ground to the high point on the stock roof rack? I would like to be sure that I will still be able to get into my garage before I buy the kit. If I cannot I will need to go with a smaller lift or just a leveling kit.
Thanks!
Thanks!
