Two questions before I do my brakes
sbbamafan
After reading and researching pads it looks like I will order Wagner Thermoquiet pads for my T4R. I haven't done my own brakes in about 25 years.
First - Does anyone have a step by step instruction specifically for the T4R? Pics would be great.
Second - How much should it cost me to get my rotors turned and where should I go? I thought NAPA would be a good choice but I stopped there and they wanted $40 EACH. Is this nuts or is this the going rate these days?
Thanks in advance.
Turning your rotors shouldn't be that much. It's about $10-20 in my area depending on shop. See if you have a CSK, Checker, Schucks or Kragen, around your area. CSK was charging ~$13 about six months ago.
Shouldn't have to bleed the system unless you get air in it.
Or maybe want to change the brake fluid as well.
I did a write-up in the maintenance section somewhere.
I think one of the most important parts about this job is cleaning and lubing the slide pins. I lube-up the anti-rattle shins as these rust and disintegrate.
DSC00048.jpg~original
A green thick grease that I pick up at the auto parts store. It is made specifically for brake jobs. I would never do a brake job without it.
I see you're in Roswell... I'm actually in Canton.
I use Kauffman Tire to turn the rotors.. I think its $10 ea. and they do it while you wait.
you dont need lube, you don't need to bleed your fluid! bleeding your brakes is a waste of fluid, unless you are adding dirt when you put fluid in, you don't need to! Lube when you need to do a "lube job" you dont need it for breaks! especially because you dont want the pads to get anything on them or they will wear unevenly.
Just a suggestion.
Take a wheel off and look at the pad material. (in particular the front pads). If one is thinner than the other, you may have had a piston that froze. Skip the pad job and source out new calipers and parts before deciding to have the brakes done.
Thrak -
I use Kauffman for a lot of little stuff but they wanted a bit much for the brake job. I also wasn,t real sure about the pads they offered. Fact is they are only about 1 mile from my house - maybe I'll get them to turn the rotors but I hate for them to give me a hard time about doing my brakes myself...generally speaking, they are pretty good guys.
sbbamafan said:
Thrak -
Yeah I dont let them do the brake job.. I just yank all 4 rotors and drive them over there. :)
